Bridge pin hole slotting saw options http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=51636 |
Page 1 of 2 |
Author: | SnowManSnow [ Thu Feb 21, 2019 12:35 pm ] |
Post subject: | Bridge pin hole slotting saw options |
What tools do you guys use to do string slots at the top of your bridge pin holes? SM has job specific tools but as usual they seem pretty high. Just wondered what you all used. Thanks B Sent from my iPhone using Tapatalk |
Author: | Mark Chinworth [ Thu Feb 21, 2019 12:53 pm ] |
Post subject: | Re: Bridge pin hole slotting saw options |
http://www.frets.com/FretsPages/Luthier ... otsaw.html |
Author: | Colin North [ Thu Feb 21, 2019 12:58 pm ] |
Different thicknesses of jigsaw blades ground down at the back and fitted with a handle for initial slotting, refined with a 5.5" Bahco Round Needle File. Cut the string ramps with dremel and round bits. |
Author: | Rodger Knox [ Thu Feb 21, 2019 12:59 pm ] |
I use something similar. |
Author: | dpetrzelka [ Thu Feb 21, 2019 1:13 pm ] |
I had used homemade jigsaw blade style slotting saws for a couple years—they work, and will get the job done. But they have a tendency to grab/jump. ![]() ![]() ![]() I finally picked up the two sizes from Stew Mac, and if you are going to do more than a few bridges worth of slotting, they are absolutely worth it. The teeth on theirs are symmetrical triangle teeth, negative hook angle—they cut slower, but much smoother than the jig saw blades I've used. If you could find jigsaw blades with very low, or negative hook angle, those would work best. |
Author: | meddlingfool [ Thu Feb 21, 2019 2:06 pm ] |
I use an old coping saw blade, then triangular then round needle file... |
Author: | jfmckenna [ Thu Feb 21, 2019 3:23 pm ] |
I got one from SM many years ago, probably 20 years now, and still use it. It looks like it was just a jigsaw blade mounted in a handle though. The pull saw option seems like a better idea though. |
Author: | Hans Mattes [ Thu Feb 21, 2019 5:30 pm ] |
I've been using a narrow end mill in a Dremel, finding it easier to avoid damaging the pin hole rather than using a saw. |
Author: | Mike OMelia [ Thu Feb 21, 2019 6:19 pm ] |
Why worry about stewmac prices? Just buy it. If everybody built guitars, prices would be lower, but then so would yours. |
Author: | Rod True [ Thu Feb 21, 2019 6:47 pm ] |
Like Terry, I use my jigsaw. Has thick cork on the bottom. Lots of control and quick. Mario P (aka: Grumpy) turned me on to that tip. Finish up with micro round file. |
Author: | meddlingfool [ Thu Feb 21, 2019 7:31 pm ] |
Ballsy! |
Author: | dpetrzelka [ Thu Feb 21, 2019 8:18 pm ] |
I'm getting out the power tools on my next one. |
Author: | kjaffrey [ Thu Feb 21, 2019 8:19 pm ] |
I also you a jig saw with a thin blade. Scared me to death at first but it has worked great. Kent |
Author: | rbuddy [ Thu Feb 21, 2019 10:00 pm ] |
https://www.amazon.com/Xacto-X215-Blades-15-Pkg/dp/B000BREQDO/ref=sr_1_1?ie=UTF8&qid=1550804129&sr=8-1&keywords=xacto+keyhole+saw+blade Also fit a fret slot perfect for easy radiusing, cleaning, deepening...just plain handy. Ya gotta try 'em, you'll like 'em. |
Author: | Pmaj7 [ Thu Feb 21, 2019 10:44 pm ] |
I use the stewmac saw they were selling 10 years ago. It cuts on the push and works great except for sometimes the blade bends and you have to straighten it out. I use a chisel to shave the top of the groove for the windings. I also tried the power jigsaw after seeing many doing it on here. I was pretty scared so I tried it on a cheapie and what do you know, it worked a treat! That cork bottom idea sounds like a good bit of insurance, however when you are pushing down and forward on the jigsaw it's pretty solid and steady as she goes. New username, same Pat Mac |
Author: | Rod True [ Fri Feb 22, 2019 12:40 am ] |
The cork is also soft so as not to mar the bridge ![]() |
Author: | Mike Collins [ Fri Feb 22, 2019 8:01 am ] |
I use a Dremal with a 113 bit. Mike |
Author: | jfmckenna [ Fri Feb 22, 2019 9:08 am ] |
You guys have me almost convinced to use a jig saw but dang, one mistake and.... |
Author: | Bryan Bear [ Fri Feb 22, 2019 10:25 am ] |
jfmckenna wrote: You guys have me almost convinced to use a jig saw but dang, one mistake and.... I'm thinking the same thing. Everyone seems to have success with it, I'd be the one to screw it up. All I have access to is a really, really old jigsaw. I really have no other need to get a newer one. Are there any features that your saws have (that mine would not) that makes this doable? This might be a dumb question, but not as dumb as using it on a guitar without asking. . . |
Author: | Barry Daniels [ Fri Feb 22, 2019 11:26 am ] |
How do you not overshoot the depth of the slot with a jigsaw? It just seems like such overkill. I have been using the new Stew-Mac slotting saws and files and they cut very smoothly and let you sneak up on the required depth without any pucker factor. |
Author: | Rod True [ Fri Feb 22, 2019 11:30 am ] |
For those thinking of trying the jig saw, make up a test piece with some 3/16” holes with the bridge pin countersink. Drill as many holes as you need to get comfortable doing the job. It’s really very simple. You don’t need to push the saw much at all and just pay attention to the blade. Sent from my iPhone using Tapatalk |
Author: | Woodie G [ Fri Feb 22, 2019 12:17 pm ] |
We use a cordless Milwaukee M12 jig saw equipped with a Bosch 101AO blade...the jigsaw's plastic shoe cover eliminates the need to tape the bridge for protection, and the variable speed capability of the Model 2445-20 saw makes precise control easy. Final cleanup is done with a needle file and the StewMac bridge slotting files. After years of using a mix of cordless tool brands in the shop, we've moved to the M12/M18 Milwaukee line for everything. Just the cost savings on batteries is a good reason, but Milwaukee seems to be making the right tools for us at affordable prices. |
Author: | Pmaj7 [ Fri Feb 22, 2019 8:12 pm ] |
Bryan, I used an older cheapie one, and while it would be nice to have that smooth and quiet Festool feeling, the old cheapie was pretty adequate. I'm surprised that no one else has mentioned using chisels to widen the slot for the windings. That's how I learned as a repair apprentice when I started and just figured it was standard. I do like using Sharp chisels whenever possible, you just have to be careful not to take more off of one side than the other. I just shave the sides rather than trying to do it all in one go. New username, same Pat Mac |
Author: | Bryan Bear [ Fri Feb 22, 2019 9:57 pm ] |
Thanks Pat. Good to know! |
